Uninstall
freddie29
Uninstall
Post by freddie29 » Mon Oct 03, 2011 9:31 pm
Is it possible to uninstall Audacity and LAME? Please forward instructions. Thanks.
Re: Uninstall
Post by Gale Andrews » Mon Oct 03, 2011 9:49 pm
Drag the the "Audacity" folder, any dmg or zip files you downloaded and "libmp3lame.dylib" to Trash.
If you were not able to export MP3s after all, you can export as WAV or AIFF from Audacity and convert that WAV or AIFF to MP3 in iTunes. To do that, click the following link:
http://wiki.audacityteam.org/wiki/Expor ... od#convert
Re: Uninstall
Post by kozikowski » Mon Oct 03, 2011 10:11 pm
'Find' does not return a hit for that file. I must have one because MP3 export works.
Make sure that Desktop > Go > Home > Library > Application Support > audacity folder is gone, too. Drag that to the Trash.
Re: Uninstall
Post by Gale Andrews » Mon Oct 03, 2011 11:59 pm
Is that because it's in /usr and you need to search protected folders to find it?
If freddie29 got the zip of LAME and installed it in his own user space then FInd should find it.
kozikowski wrote: Make sure that Desktop > Go > Home > Library > Application Support > audacity folder is gone, too. Drag that to the Trash.
Be aware that removes your former Audacity preferences if you should ever decide to use Audacity again.
freddie29
Re: Uninstall
Post by freddie29 » Sat Oct 15, 2011 12:17 am
The item “Lame Library v3.98.2 for Audacity.pkg” can’t be moved to the Trash because it can’t be deleted.The item “Audacity” can’t be moved to the Trash because it can’t be deleted.
These are the messages I get when dragging the files to the Trash. Any suggestions of how to Uninstall?
The virus scan isn't reporting any problems; can I assume these downloads won't affect my computer if whether or not I can uninstall?
Re: Uninstall
Post by Gale Andrews » Sat Oct 15, 2011 6:13 pm
freddie29 wrote:The item “Lame Library v3.98.2 for Audacity.pkg” can’t be moved to the Trash because it can’t be deleted.The item “Audacity” can’t be moved to the Trash because it can’t be deleted.
Make sure you have done Audacity > Quit Audacity so that it isn't running, or Command - Option - Esc to bring up Force Quit.
If you installed to somewhere you need admin permissions, then you need the same admin permissions to delete files.
You can also try Go > Utilities > Disk Utilities. Select your system drive and Verify Disk and then when that's done, Repair Permissions.
Otherwise contact Apple support if you cannot delete files on the system.
freddie29 wrote:The virus scan isn't reporting any problems; can I assume these downloads won't affect my computer if whether or not I can uninstall?
If you obtained Audacity from http://audacityteam.org/download/ then remaining files should not affect your system in any way.
Re: Uninstall
Post by kozikowski » Sat Oct 15, 2011 6:23 pm
Are you on a corporate or business machine? Did you get your Mac from someone in the IT department? you will not be able to change the software without talking to them.
Are you an Administrator on your Mac? Apple (upper left) > System Preferences > Accounts. Mine looks like the picture and I can install and remove software.
A remote possibility is your Virus software is preventing you from "damaging" your computer by deleting software. Consult your directions.
Screen shot 2011-10-15 at 11.13.41 AM.png (18.6 KiB) Viewed 3184 times
freddie29
Re: Uninstall
Post by freddie29 » Tue Oct 18, 2011 10:40 pm
No affect on computer function with Audacity; does that include LAME?
Thanks for all your help.
Re: Uninstall
Post by Gale Andrews » Tue Oct 18, 2011 10:57 pm
freddie29 wrote:No affect on computer function with Audacity; does that include LAME?
Any remaining files including LAME or FFmpeg (for reading and writing extra audio and video formats) will not affect the computer. Other programs that look for LAME and FFmpeg libraries might try to use those libraries.
But if you own the computer and you are the administrator of it, you should be able to delete whatever files you want.
