location of eqcurves.xml file in mac osx 10.7 lion
stu1
Post by stu1 » Mon Oct 03, 2011 10:22 am
hi guys
i can't find the eqcurves.xml file in mac osx lion. for that matter, there is no audacity folder in library/application support in which it is supposed to live. any ideas please? thanks.
Re: location of eqcurves.xml file in mac osx 10.7 lion
Post by Gale Andrews » Mon Oct 03, 2011 7:57 pm
EQDefaultCurves.xml should be in the package or zip at /Audacity/Audacity.app/Contents/Resources/EQDefaultCurves.xml . EQDefaultCurves.xml provides the nine default preset curves for Equalization and an initial flat "unnamed" curve.
If you obtained the .dmg of Audacity it should be installed thus:
1 Double-click the downloaded .dmg to mount it
2 Then to install Audacity, copy the "Audacity" folder from the newly mounted .dmg to /Applications or any other location of your choosing
3 Then run Audacity from the folder you copied it to.
Whenever you open Equalization and click OK, EQCurves.xml will be written to ~/Library/Application Support/audacity. EQCurves.xml will represent the curve points of the current "unnamed" curve and of all the preset curves including any presets you added. If you click OK in Equalization without changing any curves, EQCurves.xml will just be a backup copy of EQDefaultCurves.xml.
See http://manual.audacityteam.org/man/Equalization .
If that does not help, please explain in more detail what you trying to do.
stu1
Post by stu1 » Tue Oct 04, 2011 6:03 am
"EQDefaultCurves.xml should be in the package or zip at /Audacity/Audacity.app/Contents/Resources/EQDefaultCurves.xml"
--i just see the app, named Audacity. it's not actually called Audacity.app apparently. i can't see a folder called contents.
Nor is audacity in Library/application support. Annoying: it always was there when i was running mac 10.6!!
the reason i want to get at the eqcurves.xml file is that when i was using 10.6, i was modifying it using a text editor to create complex eq curves.
thanks for considering.
billw58
Post by billw58 » Tue Oct 04, 2011 3:35 pm
Right-click on the Audacity application. Choose "Show package contents" - a new window opens. It has a folder called "Contents" - open that folder. It has a folder called "Resources" - "EQDefaultCurves.xml" is in that folder.
Which "Library/Application Support" are you looking at? The one at root level or the one in your user space?
-- Bill
Post by Gale Andrews » Tue Oct 04, 2011 11:54 pm
stu1 wrote:the reason i want to get at the eqcurves.xml file is that when i was using 10.6, i was modifying it using a text editor to create complex eq curves.
Did you save any of the complex curves as presets? If so and you can see them, then Audacity is reading the EQCurves.xml file OK.
Also if in the Audacity Equalization effect you click "Save / Manage Curves..." then "Export", the window should open at ~/Library/Application Support/audacity and show you EQCurves.XML.
stu1
Post by stu1 » Wed Oct 05, 2011 4:29 am
I now see that audacity has put eqcurves.xml into user/library, not root/library. it's never done that before; oh well. To further confuse things, user/library is invisible!! i got it to become visible within a "save as" dialog box by doing <shift><command><.>
thanks very much for your help, guys.
billw58
Post by billw58 » Wed Oct 05, 2011 2:00 pm
stu1 wrote:i got it to become visible within a "save as" dialog box by doing <shift><command><.>
Nice trick!
<user>/Library became invisible with 10.7. Not one of Apple's best decisions IMO.
-- Bill
Post by Gale Andrews » Thu Oct 06, 2011 12:00 am
billw58 wrote:<user>/Library became invisible with 10.7. Not one of Apple's best decisions IMO.
I know they were threatening to, but did not realise they had done it. Other workarounds (including a permanent one) to show ~/Library here:
http://osxdaily.com/2011/07/22/access-u ... os-x-lion/
So this means that audacity.cfg is also now hidden on Lion.
I also see Lion now hides /lost+found to make it easier to "lose".
If you export an Audacity EQ curve on Lion, where does the window open to?
