How to have a pausing point
OfficialKage
I'm a rapper And i would like to have a nice mute point. You know like when rappers spit their punchline the beat stops and you just hear them and then the beat continues ..
Re: How to have a pausing point
Upgrade to Audacity 1.3.13 (get it here: http://audacityteam.org/download/)
Click on the track at the point where you want the pause, then "Edit > Clip Boundaries > Split" (or Ctrl+I).
Switch to the Time Shift tool (F5 key) and drag the right hand section to the right.
When you play back the track you now have a pause.
OfficialKage
Didn't understand after the split part..
Which version of Audacity are you using?
OfficialKage
1.3 . But i mean like pause the beat but keep my voicing going
Right. That's we're talking about. It happens in post production, not in real time. You would record your vocal track and go back and split the backing track (two separate tracks) and push the backing track forward so there's a hole. During the hole, it's your voice with no track.
If your voice and the backing track are all one, you need to start over. Editing depends on you having separate tracks for everything.
You could also do it by playing the track but only rap until the split point. Then cut the split and play that and continue the voice as a third track. Mix together later.
You could also split the backing track ahead of time and record the voice over that. That's probably the easiest.
OfficialKage
When I try to spit it and move it with time tool it won't move though.. Only my vocals do
- Quality Assurance
As I understand it you only want to split the backing track, so click above the Mute / Solo buttons in the backing track to select just that track, then split (CTRL + I) starting from the left so that you have somewhere to move the clip to.
Or click and drag to select a section for pause and silence (CTRL + L), or Edit > Silence Audio in 1.3.13, Edit > Remove Audio > Silence Audio in 1.3.14. But you don't get a separate clip for the silence that way. A clip can be useful because you can double-click in it to select it.
OfficialKage
I just did silence and it worked thank you
