vocal remover not showing in the list
lastest beta version just installed. vocal remover is not in the pull down list.
Re: vocal remover not showing in the list
In Preferences -> Effects make sure Nyquist is checked. If it's not, check it and restart Audacity.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
