I have deleted the Meter Toolbar...
conhick41
Post by conhick41 » Thu Sep 29, 2011 3:42 pm
...and can't seem to get it back???
Re: I have deleted the Meter Toolbar...
Post by steve » Thu Sep 29, 2011 4:23 pm
Are you sure that you are using Audacity 1.2.x?
(if in doubt, look in "Help > About Audacity".)
conhick41
Post by conhick41 » Thu Sep 29, 2011 6:05 pm
Checked there, it says Audacity 1.2.6
It's giving me the option to Float Meter Toolbar in view but When I do that I can't see it anywhere and then it doesn't give me the option to Dock Meter Toolbar??
Post by Gale Andrews » Thu Sep 29, 2011 6:34 pm
Click Edit > Preferences then "Interface" at the top. Use the arrows if you can't see "Interface". Make sure "Enable Meter Toolbar" has a check mark (if there is no check mark, click in the box for that item). Then click OK.
If you still cannot see the Meter Toolbar, you probably floated it off screen, To fix that, File > Exit and restart Audacity.
conhick41
Post by conhick41 » Thu Sep 29, 2011 6:52 pm
That worked a treat! Thanks a million!
