Volume changes while recording
bcrich1234bc
A few seconds after starting to play then volume drops. It's almost like im dropping the input level. It's getting really annoying and i've got no idea what to do.
Re: Volume changes while recording
You miss some important pieces of information... Which Audacity version and which operating system?
I bet you're on Windows and that's probably windows trying to "help" you.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
Check this topic in the manual: http://manual.audacityteam.org/man/FAQ: ... hancements
bcrich1234bc
Audacity 1.3 Beta and yes, Windows 7.
The most likely cause is the "Enhancements" that Windows provides (for the purposes of voip programs such as Skype, voice recognition programs, and similar). These Enhancements make a mess of music recordings. Finding exactly where to switch these Enhancements off can be quite complicated to explain, so some kind soul has written up the instructions. You'll find them in the link that Koz provided.
bcrich1234bc
Ok thanks guys, I'll check that out and say what happens...as soon as i finish my paper and chem homework >.>
