willsband wrote:I usually just start Audacity and then start recording; then when done recording I save it. Would it be better to open a new project before I start recording?
If Audacity is not running and you launch it to start a recording, there is no need to open a new project window. The concern would be if you kept on recording new tracks in the same project window (even if you closed the old tracks using the [X] to left of the tracks). If you do that, you come up against the possible 13.5 hours limit.
And if you keep opening new project windows without File > Close on the old ones, you eventually run out of disk space because the data for all the projects is still stored.
willsband wrote:I looked in the help > show log and only did not find any errors. However, I was working on a new project and I don't know if the log keeps the older data.
The log persists while the Audacity program is running, irrespective if you start a recording then open a new project window or close the old window. Once you Audacity > Quit Audacity, the log is gone.
willsband wrote:I was not able to locate the Autosave file.
Please say if you ever specifically did "File > Save Project" or "File > Save Project As" on this recording. If yes and there are no unsaved changes (File > Save Project is greyed out), there will be no AutoSave file, but you could generate one just by making a selection in the track. If you saved a project, the first place to look for the audio data is in the _data folder that has the same name as the .aup file.
If you never saved the recording as a project, is the recording still open in a project window? If so, the data should be in the temp folder you indicated (and there would be an AutoSave file).
So you need to look in one of those two locations according to whether you saved a project or not, and see what data is there. There is always a chance you have hit a rare bug and Audacity has moved the .au files somewhere it should not have done. But if so and you play the track, it should generate "Can't open file" in the log.
