Because I'll have more than a few files to save, I want to save space by cropping leading and trailing unimportant sounds (chatter before course and students getting out). Loving audacity, I've used it to open the wav files but nothing plays. The first thing I notice is that the waveform is perfect, like it was made from a synthesizer or audio production software. Then with the Fit in Window view, about the first 1/4 seem to indicate it's near-silent, the next 1/4 seem to be gaining in volume (lacking the technical term), and the last 1/2 seem like it was too loud and the wave peaks are at the limit (reach a ceiling? level out?). I then notice something that wasn't obvious at all as it's on the same scale, the recording is about 120 minutes and the right-hand time index contained 120 but when I used the Zoom Normal view, it disappeared and after a couple minutes realized the whole thing wasn't even a second long, in fact it was ~0.0120 second ; quite short to weigh 39Mb!
During my course break, I wanted to make an AAC version (so I'd keep that on my computer then move the wav on my backup) but I failed miserably using MediaCoder trying a few codecs. I settled for a VBR MP3 (but wouldn't move the wav before I get the AAC). So IMA ADCP can be converted to MP3 and I suppose the reason it doesn't cut it for aac is the same as I can't play the wav with audacity.
Help or tips on how to get this wav file properly imported so I can edit it's sound would be appreciated.
Update 1:
I modified my profile then viewed my previous posts taking notice to IMA ADPCM can't import, it's odd that google didn't find that in my search.
Update 2:
I noticed there was a 2nd point on the installation guide. Well I still imported the same wav file after the plugin installation but it didn't ask me anything for the configuration and I can't even reach Edit > Preferences: Libraries on Audacity.
