Mac 10.4.11 File Path for toolbar help button
Hello all, I am recovering from a crash and cannot find the correct file path for Help button in toolbar. I would appreciate it tremendously if someone could post this from a Mac 10.4.11 OS-the problem is that the help manuals are there and if I press the help option I get a window asking me to find the manuals and open them-before the crash the Help button called up the manuals properly, thanks for your kind help.
Re: Mac 10.4.11 File Path for toolbar help button
You can search for the path. The filename is audacity-1.2-help.htb. Version 1.3 isn't nearly so helpful. Try substituting 1.3 in the filename.
I don't have any of the help systems loaded on my machine, so I'm flying blind.
koz
koz
I was able to access the on-line help system, but there may not be a downloadable one any more.
