how do i insall a mic
mikeouk
Post by mikeouk » Thu Sep 13, 2007 8:14 am
hi,im wanting to record some lines i need to learn and save as a mp3 so i can put it on my ipod.Im totaly green with this and cant work out how to install and use a mic to audacity. will i have to buy a mic or can i use a usb telephone i already have, im not bothered about it being quality.
cheers
mike
alatham
Re: how do i insall a mic
Post by alatham » Thu Sep 13, 2007 2:19 pm
You didn't mention anything about your computer or what kind of USB telephone you have. It's hard to help until you tell us that stuff.
I can tell you how to set Audacity up to use a mic (though you could have just read some documentation).
Open Audacity and click Edit -> Preferences -> Audio I/O tab. Here, you'll need to select your Recording source (I don't know what it will be called, you didn't mention) in the drop-down menu (95% of people have to turn off Software Playthrough also). Then make sure Audacity's input volume is turned up about halfway (the slider has a mic icon next to it) and press record, do you pick anything up?
Post by kozikowski » Thu Sep 13, 2007 4:25 pm
<<<anything about your computer>>>
If you're on a Mac laptop, you launch Audacity and talk into the built-in microphone. Export it as a WAV file, open it in iTunes and sync to your iPod.
If you're on a Windows machine, there's a $25 Radio Shack microphone we use for just about everything and it works remarkably well.
But first, you have to part with more information. I don't like working in a vacuum. My eyes bug out and my ears pop.
mikeouk
Post by mikeouk » Thu Sep 13, 2007 9:41 pm
kozikowski wrote:<<<anything about your computer>>>
sorted,thanks alot for the advice.
