MP3 Playback - not - OS X Lion
kbbrowning
Post by kbbrowning » Mon Sep 05, 2011 4:29 pm
I'm just getting to using Audacity since upgrading to OS X 10.7.
When I open a mp3 file (or other) in Audacity (1.3.13 - also earlier versions before I updated this), the graph is displayed. When I press play the cursor line "jiggles" but does not progress forward. I've tried this on several file with the same outcome.
Because I've aggressively used Audacity in the past, I am SUSPECTING the problem is related to the Lion upgrade - but don't really know for sure.
Thanks for any help you can offer.
Karl
Re: MP3 Playback - not - OS X Lion
Post by kozikowski » Mon Sep 05, 2011 4:36 pm
Launch Audacity cold and generate a tone. Does that play?
kbbrowning
Post by kbbrowning » Mon Sep 05, 2011 5:06 pm
Thanks for the quick response.
No. It behaves the same. I attached screenshot if that helps.
Notice the green inverted triangle at 0. When I press play, it blinks but doesn't move.
Karl
Screen Shot 2011-09-05 at 12.40.34 PM.png (73.36 KiB) Viewed 1004 times
kbbrowning
Post by kbbrowning » Mon Sep 05, 2011 6:56 pm
Arrrrrrrrgh!!!!
I had need to reboot. After reboot, this worked the way it should.
I'm sorry to have taken your time - this is not something I normally expect from Apple Macs.
Regards
Karl
