Eliminating mic buzz
halim4all
Post by halim4all » Sat Aug 27, 2011 5:36 pm
I'm working with a single voice speech recorded with 2 mics, one of which buzzes now and then.
Any suggestions on eliminating the 2nd mic's buzz? There are words on both tracks at the same
time as the buzzing, but I can't separate mic the tracks (mono recording).
halim4all
Re: Eliminating mic buzz
Post by halim4all » Sat Aug 27, 2011 9:02 pm
I've done it! A friend called to tell me how to split the tracks into two duplicates
and then simply delete the offending track! Yay!
Post by kozikowski » Mon Aug 29, 2011 2:54 am
Yes, but you shouldn't need to do that. Describe how your system is connected. Macs don't have a Mic-In, so how did you get there?
