This read-only archive contains discussions from the Adding Feature forum.
New feature request may be posted to the
Technical support is available via the
Help forum.
nilolaus
Post
by nilolaus » Tue Aug 16, 2011 10:51 pm
Ok - thank you again for your help - I really appreciate!
There will be some work to do the next few days and hopefully not too many more questions
Greez - Niko.
nilolaus
Post
by nilolaus » Mon Aug 29, 2011 10:29 am
Hallo!
One more question: Can I use the same .mo-file for mac and windows-versions? Means: I edit the mac .mo to get a simplified version of the menus (there will be nothing left than "export" and "quit"). Can I then use the same file for the windows-version or do I have to do everything again on the windows system for the windows version?
Greez
Niko
- Quality Assurance
Post
by Gale Andrews » Mon Aug 29, 2011 12:11 pm
nilolaus wrote:Can I use the same .mo-file for mac and windows-versions? Means: I edit the mac .mo to get a simplified version of the menus (there will be nothing left than "export" and "quit"). Can I then use the same file for the windows-version or do I have to do everything again on the windows system for the windows version?
The .mo files can be read on all platforms but you can't edit the .mo files. The .mo files are produced by editing the .po file then compiling the .mo file. That will usually be done by "saving" the edited .po file in the .po editor (such as
Poedit).
nilolaus
Post
by nilolaus » Mon Aug 29, 2011 1:08 pm
Hallo!
Sorry ... yes ... of course. I am already in the stage of editing the .po and i did already save some test-versions of .mo-files. I just mixed up the terms.
Sorry there are some more questions, for the deadline is hanging directly in front of my nose. May be there is a possibility for a little donation as soon as the customer paid.
I understood that the only versions I can use with simplified language .mo files are the nightly builds - am I right? A problem I have with the latest build (8.28) is that a project I save does not read the audio-files (saved with the project) when launching again. Instead there is a window coming up, telling the alpha-version of the software.
An older nightly-build on which i worked until today, does not show this window but loads the audio without any problem. I do of course not think that there is a correlation between showing this window and not loading the audio
but an inverse behavior would be much better.
Greez
Niko
- Quality Assurance
Post
by Gale Andrews » Mon Aug 29, 2011 3:16 pm
nilolaus wrote: May be there is a possibility for a little donation as soon as the customer paid.
All donations are welcomed, thanks!
nilolaus wrote: I understood that the only versions I can use with simplified language .mo files are the nightly builds - am I right?
No. The ability to hide menus if "!" is in the .po file has remained enabled since the time it was implemented, so will work in the current 1.3.13 Beta version too. What we aren't doing is providing any "simplified" .mo files ourselves.
nilolaus wrote: A problem I have with the latest build (8.28) is that a project I save does not read the audio-files (saved with the project) when launching again. Instead there is a window coming up, telling the alpha-version of the software.
The problem with the superfluous window was introduced (on Mac only) on the 17th August and is waiting for more testing to fix it. So any "nightly" build before then or indeed 1.3.13 Beta would not have that problem.
klimmbimm
Post
by klimmbimm » Thu Sep 22, 2011 9:59 am
Gale Andrews wrote:nilolaus wrote:As far as I understand... we can include this folder into our download-package and on the computer, where Audacity is downloaded, Audacity will use the .cfg-File insider the "Portable Settings" folder instead of creating a new one. Am I right?
On each launch Audacity will look first for audacity.cfg in a "Portable Settings" folder in the Audacity installation directory and use those settings. If it cannot find audacity.cfg there it will look in Audacity's
data directory. If audacity.cfg is not there either (as would normally be the case with a fresh installation) then Audacity will launch with default settings. It will be simpler for you to add the "Portable Settings" folder in the installation directory (@ Peter - indeed it does work).
I copied my Audacity folder (with Audacity 1.3.13) to another computer including the "Portable Settings" folder. But when I ran audacity.exe on the other computer it doesn't recognize the settings.
Did anyone experience a similar behaviour?
nilolaus
Post
by nilolaus » Thu Sep 22, 2011 2:34 pm
Hi!
I did the same and it worked. May be you have the wrong .cfg-File in your Portable settings folder.
Greez
- Site Admin
Post
by steve » Thu Sep 22, 2011 4:44 pm
or, if Audacity was already installed on that computer, perhaps you're running the wrong audacity.exe file?
klimmbimm
Post
by klimmbimm » Mon Sep 26, 2011 9:46 am
OK, I assume that the "PresetsDir" line in audacity.cfg was set to an old path.
