I cannot record? What am i doing wrong?
ShuriiX
Re: I cannot record? What am i doing wrong?
Post by ShuriiX » Fri Aug 19, 2011 11:29 am
kozikowski wrote:I know somebody whose "Record Out" doesn't work. You can test the cables by touching them. Set Audacity to recording and touch the hot end of one of your cables instead of plugging it into the amp -- like this, but your cables may be different.
http://kozco.com/tech/audacity/pix/touch.jpg
You are intentionally creating buzz and hum with the idea of troubleshooting.
If that fails, the cable may be bad.
I get no buzzing, on either cables, by 'the cable may be bad' do you mean unable to record, or just broken?
Both cables work while playing guitar... :?
Post by Gale Andrews » Sat Aug 20, 2011 1:01 pm
So try putting one end of the cable into audio out and the other into line-in and record from Audacity using line-in.
ShuriiX
Post by ShuriiX » Sun Aug 21, 2011 3:59 am
Gale Andrews wrote:So try putting one end of the cable into audio out and the other into line-in and record from Audacity using line-in.
No offense, but i tried that, and it didn't work which is the entire reason for this thread :$
It's the reason i don't know why it doesn't work...
Post by steve » Sun Aug 21, 2011 9:34 am
Topic moved to the Windows > audacity 1.3.x forum.
When you try to record the guitar, do you get a flat blue line like this:
If you do, try selecting a section in the middle of the track and apply the Normalize effect using "Normalize to: 0 dB".
Does the selection remain as a flat line after applying the Normalize effect?
Post by Gale Andrews » Sun Aug 21, 2011 11:36 am
No offence taken, but you asked was there any other way to test the line-in and I don't see anywhere in this thread until now where you say you tested with audio out.
Can you still give us (as well as the answer to Steve's question)
  • An image of the listed devices when you click the output device and input device dropdowns in Device Toolbar
  • An image of the Recording sections of "Sound" and "Sounds and Audio Devices" in 7 and XP respectively
Maybe we could take one computer at a time, whichever is most easy for you.
ShuriiX
Post by ShuriiX » Tue Aug 23, 2011 8:55 am
My mistake, i thought i stated that i used record out, which is the only other input i have on my amp, but nevermind that.
I have attached the images you requested, of the computer with windows 7.
This is the device toolbar, i couldn't find the output and input device dropdowns, though..
Untitled-2 copy.jpg (81.14 KiB) Viewed 1359 times
This is the recording section of sound, i couldn't find sounds and audio devices anywhere in the control panel though, even with search.
ShuriiX
Post by ShuriiX » Tue Aug 23, 2011 8:57 am
steve wrote:Topic moved to the Windows > audacity 1.3.x forum.
Yes, it does.
The image above is basically what i get when strumming, nothing even shows up on the little mixing tab next to it.
My apologies for not replying to both in the same post, i didn't see yours until after i posted the first one.
Post by steve » Tue Aug 23, 2011 1:13 pm
ShuriiX wrote:nothing even shows up on the little mixing tab next to it.
I don't know what you mean. Could you post a screen shot of that?
Did you try "Amplifying" the flat line?
Post by Gale Andrews » Tue Aug 23, 2011 11:40 pm
I meant connecting audio out (green) of the computer to line-in of the computer.
I meant can you shows us screenshots of the input and output device dropdowns in Audacity's Device Toolbar .
The Windows Control Panel for audio is called "Sound" in Windows 7 and "Sounds and Audio Devices" in Windows XP.
If you amplify the flat line it will let us know if you are recording absolute silence or low level noise, or a low level signal of what you intend.
ShuriiX
Post by ShuriiX » Thu Aug 25, 2011 9:10 am
Look to the right of the 'line in' picture, those bars usually bounce up and down when something is played into the microphone source etc.
And yes, it did nothing.
