No (though I can see that could be useful too)Gale Andrews wrote: .. Are you (Peter) asking for a way to adjust the Timer Record stop time once you have started it?
What I am asking for is to be able to do in Timer Record mode all the things I can do in normal record mode: zoom in/out, change the track size, drop markers with Ctrl+B and Ctrl+M, use the sliders to adjust the signal, change the waveform display type, rename the track etc.
The underlying problem, I infer, is that whoever write the Timer Record assumed it was for "unattended recording" - if that was what it was intended to be then we should have called it "Unattended Record".
Use Case: I often use Timer Record while I am active on my PC so that I do not forget to start an FM capture from the radio (I'm using it right now in fact to capture Mike Harding's show on R2) - and that case I do want and need access to the tools.
Peter.
