capturing audio on reverb
gqsmuv
Post by gqsmuv » Wed Aug 10, 2011 8:57 pm
good day, just join this forum...
trying to capture audio from reverbnation...the entire track seems to have been caught, but after exporting to mp3 (as well as during playback), it sounds like it capture all external sounds and the actual audio track sounds really 'stripped'-like...sounds faint/distant and just bad...
i've tried all the settings with MME and Windows Direct
i'm running on windows 7
please help, thank you
Re: capturing audio on reverb
Post by kozikowski » Wed Aug 10, 2011 9:39 pm
You never said how you were trying to capture your show. Actual physical devices and part numbers.
It sounds like you're really capturing your laptop's built-in microphone. The symptoms are a really bad sounding show and also listening to your breathing, the dogs upstairs and the metrobus outside your window. Setting that's a job for proper settings in the Windows Control Panel.
gqsmuv
Post by gqsmuv » Thu Aug 11, 2011 5:53 pm
its basically a built in sound card from the dell latitude e6400
the only options i have is MME and Windows Direct when opening Audacity
iv'e tried it on a different computer as well, a vostro 1520..i seemed to have the same issue as well...
i've clicked on your link and there's really no other options for me to check settings...all i have is the attached files in this thread
thanks
playback
recording
