White noise
jbn
White noise
Post by jbn » Tue Aug 09, 2011 3:44 am
Hi,
I am new to Audacity. Please forgive me if this is not an appropriate venue for this question.
I would like to create 10 minutes of "white" noise, but only including frequencies above 5KHz. I assume I would want some smoothing of the frequencies between say 4KHz and 5KHz rather than a totally sharp cutoff.
Can such a file be created directly, or can it only be created by filtering a full spectrum white noise signal? I have tried to create the signal by filtering, but I so far have not found a filter (or possibly a set a filter parameters) that does a good job.
Any suggestions are much appreciated.
Thanks,
John
samspots
Re: White noise
Post by samspots » Tue Aug 09, 2011 5:00 pm
I'm not sure I understand what your problem is.
Try making white noise, then high-passing it at 4000 hz?
Trebor
Re: White noise (for tinnitus masker ?)
Post by Trebor » Wed Aug 10, 2011 4:20 am
jbn wrote:... be created by filtering a full spectrum white noise signal?
Yes that's the way to do it : "Generate" 10 minutes of white noise then apply a high-pass filter using the equalizer, ("equalization")," in "Effect" menu, e.g. ...
[You could get away with looping white noise after a about a minute: IMO no-one will notice it's repeating]
jbn wrote:... so far have not found a filter (or possibly a set a filter parameters) that does a good job.
5KHz sharp high-pass filter 'curve' drawn in Audacity equalizer.png (27.83 KiB) Viewed 560 times
