Toggling track muting in beta versions?
zen_city
Post by zen_city » Tue Aug 19, 2008 2:59 am
I am using a Macbook Pro to import mp3 tracks and then add my own guitar and vocals. So lots of tracks to mix.
Track muting is great when in the orginal view where I can turn various tracks on and off and listen, but when I get a big of them and choose the "fit in window" or "fit vertically" options in the view menu to do file management the mute /solo buttons disappear and I can't figure out how to toggle back to the original view. I can mute all or unmute "all tracks" but can't get back the mute and solo buttons for individual tracks anymore. 1.2 instructions don't seem to apply. Instructions? Thanks.
Re: Toggling track muting in beta versions?
Post by steve » Wed Aug 20, 2008 2:59 am
zen_city wrote:but when I get a big of them and choose the "fit in window" or "fit vertically" options in the view menu to do file management...
Use the "Collapse all tracks" (Shift+Ctrl+C) instead of "Fit to Window"
you can then use "Expand All Tracks" (Shift+Ctrl+X) to get at the mute (and other) track controls.
jan.kolar
Post by jan.kolar » Wed Aug 20, 2008 10:14 am
Did you try keyboard shortcuts, as listed in Edit > Preferences > Keyboard ?
(perhaps to be found in the Help > Index, too)
There is
Mute/Unmute focused track... Shift-U
and
Solo/Unsolo focused track.. Shift-S
Hmm, I would not like to use toggle controls if I do not see the buttons.
If you would like to have
. Mute focused track
. Unmute focused track
. Solo focused track
. Unsolo focused track
in the Preferces > Keyboard, make a feature request.
(The keys may but do not need to by assigned by default, this can be done by interrested user.)
zen_city
Post by zen_city » Sat Aug 30, 2008 12:14 am
Thanks, Steve, the expand all tracks, collapse all tracks seems to do the trick. ;)
