Not able to record
Tyler
Not able to record
Post by Tyler » Fri Jul 29, 2011 4:11 am
I have spent the last 6 hours trying to record with audacity. I have read countless forums and wiki pages, but to no avail. I am new to posting anything on forum so I don't even no if this is the right place. However, I need some assitance please. I want to use my computers built in microphone. When I push record the line is quite flat, after boosting up the amplification and the microphone when I push play after recording i just here a bunch of noice (sounds like a walkie talkie noise) however, my voice--even when yelling :) is completly undetectable. Now I used audacity a couple years ago when I had vista, but when I upgraded to windows 7 and consequently lost the audacity program. I simply reinstalled it, but now I can't get it to work. The following info may be useful.
Using:
Audacity 3.3.13 beta version
windows 7
I have done the following:
Configured the sounds on my computer like I read on wiki page.
tried every possible configuration with devices found in preferences.
I did the amplification effect.
I increased the sound of my microphone.
what can i possibly do now? Thanks for for your help!
Re: Not able to record
Post by Gale Andrews » Sat Jul 30, 2011 1:23 am
In Audacity, click Help > Audio Device Info. Click in the list, CTRL + A to select all, then CTRL + C to copy, then paste into your reply.
In the "Recording" tab of "Sound" in the Windows Control Panel, hold ALT then press PrtScr. Save the image as a PNG (not a BMP) then attach it to your reply (use the "Upload attachment" tab underneath the message "Preview/Submit" buttons).
pikoger
Post by pikoger » Mon Aug 01, 2011 6:38 am
Hi all
Similar problem. I just installed 1.3 on my new computer. Windows 7 prof; motherboard: Asus P8P67 LE rev. 3.0; sound: Realtek high definition audio; driver: 6.0.1.6251 (even higher number than latest driver on Asus site).
No problem with playing existing audio file with Audacity, but recording (for instance from Windows Media player) is not possible. No detection of audio signal.
Any help appreciated.
Piko
Default capture device number: 1
Default playback device number: 3
Device ID: 0
Device name: Microsoft Sound Mapper - Input
Host name: MME
Input channels: 2
Output channels: 0
Low Input Latency: 0.200000
Low Output Latency: 0.200000
High Input Latency: 0.400000
High Output Latency: 0.400000
Supported Rates:
Device ID: 1
Device name: Microphone (HD Webcam C270)
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 2
Device name: Microsoft Sound Mapper - Output
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 3
Device name: Speakers (Realtek High Definiti
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 4
Device name: Realtek Digital Output(Optical)
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 5
Device name: Realtek Digital Output (Realtek
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 6
Device name: Primary Sound Capture Driver
Host name: MME
Input channels: 2
Output channels: 0
Low Input Latency: 0.000000
Low Output Latency: 0.000000
High Input Latency: 0.000000
High Output Latency: 0.000000
Supported Rates:
Device ID: 7
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 8
Device name: Primary Sound Driver
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 9
Device name: Speakers (Realtek High Definition Audio)
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 10
Device name: Realtek Digital Output(Optical) (Realtek High Definition Audio)
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Device ID: 11
Device name: Realtek Digital Output (Realtek High Definition Audio)
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Selected capture device: 0 - Microsoft Sound Mapper - Input
Selected playback device: 3 - Speakers (Realtek High Definiti
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Available mixers:
Available capture sources:
0 - Master Volume
Available playback volumes:
0 - CD Audio
1 - Master Volume
Capture volume is native
Playback volume is native
Post by steve » Mon Aug 01, 2011 7:20 am
Hi pikoger,
You are currently set up to record from your webcam microphone.
Have a look here to see if it is possible to enable "Stereo Mix" recording: http://wiki.audacityteam.org/wiki/Mixer ... trol_Panel
pikoger
Post by pikoger » Mon Aug 01, 2011 10:14 am
Problem solved. Thanks a lot. piko
The solution was:
It is common on Vista and 7 that not all recording inputs are automatically enabled in the Recording tab. This means they are invisible in that tab, and also invisible to recording applications like Audacity. So you need to make them visible, then enable and make default the one you want to use, thus:
