recording
Leo van soldt
recording
Post by Leo van soldt » Wed Jul 20, 2011 1:08 pm
l.S., When I record I get a file like the attachment. What did i do wrong? I hope you can help me.
regards,
Leo van Soldt
Record 1.wav
(860.2 KiB) Downloaded 52 times
Re: recording
Post by Gale Andrews » Thu Jul 21, 2011 2:00 am
When you have a configuration problem, please help us to help you by posting to the forum for whatever operating system you are on (for example, Audacity Beta, Windows). If you tell us your version of Audacity and operating system now, we can move your topic.
What source are you trying to record? It's way too loud. Turn down the Audacity input slider on Mixer Toolbar, or the slider in the operating system, or the output knob on the recording source. If the recording source is line-level (for example, from a cassette deck or amplifier), connect it to line-in of the computer, not to the microphone port. Connecting line level output to the mic port would give you the result you have.
Leo van soldt
Re: recording
Post by Leo van soldt » Fri Jul 22, 2011 8:28 am
Hallo Gale,
Thank you for your quick reply.
I hope I can solve the problem now.
The version of Audacity I' m working with is 1.3, my operating system is Windows 7.
I assume this info suits your requirements.
regards,
Leo van Soldt
Re: recording
Post by kozikowski » Fri Jul 22, 2011 3:39 pm
That pink connector is not a stereo music connection...
http://www.kozco.com/tech/audacity/pix/ ... pSound.jpg
It was designed for a low-level mono microphone or headset like this...
http://www.kozco.com/tech/audacity/pix/PCHeadset.jpg
If you're trying to record stereo from your sound system, cassette player or other music system, you might be able to use a stereo USB adapter like the UCA202.
http://kozco.com/tech/audacity/pix/UCA202.jpg
Leo van soldt
Re: recording
Post by Leo van soldt » Tue Jul 26, 2011 9:35 am
L.S.,
I deleted the version 1.3 from my computer and I downloaded version 1.3.13Beta.
The recording is in order now.
Now I have a problem when removal clicks. I looked it up in 'wiki.audacityteam.org' and there I found out that the clicks should be removed in 2 steps. The first step I can handle, but the problem is that I cannot find the 'click Removal '-selection in the 'Edit menu'. When I give OK, nothing happens.
I hope you have a solution.
Thanks and regards,
Leo van Soldt
Re: recording
Post by steve » Tue Jul 26, 2011 2:49 pm
Leo van soldt wrote: I cannot find the 'click Removal '-selection in the 'Edit menu'.
"Click Removal" is in the "Effect" menu (if there is an error in the documentation could you post a link to exactly where it is so that it can be corrected).
"Click Removal" has to try and decide which clicks are "noise" and which clicks are part of the intended recording. This is not an easy thing to do, so Click Removal tends to err on the safe side. It will very rarely remove clicks that should not be removed, but will quite frequently fail to remove clicks that should be removed.
When using Click Removal, do not make the selection too small - allow a good few seconds of audio either side of the click(s) that you want to remove.
Another tool is "Repair". This is good for removing stubborn clicks but can only be used on one click at a time. http://manual.audacityteam.org/man/Repair
Leo van soldt
Re: Recording using Beta and Win 7
Post by Leo van soldt » Fri Jul 29, 2011 12:18 pm
Hallo Steve,
I couldnot make a link, but I have made a print-screen of the edit menu with its options and pasted it in Word.
The options are in Dutch, but I assume that the order is the same as in the English version.
I tried to copy this print-screen as an attachment, but the extensions in which Word saves the print-screen, are not allowed as an attachment. How can I get the print-screen to you?
Thanks and regards,
Leo van Soldt
Post by Gale Andrews » Sat Jul 30, 2011 1:45 am
If you were looking at http://wiki.audacityteam.org/wiki/Click ... oval_steps there was a mistake which said Click Removal was in the Edit menu, but it isn't - it's in the Effect Menu (in Dutch it is under "Klik-verwijdering" in the "Effecten" menu). I have corrected the Wiki page.
We don't need an image, but for future, the best idea is to paste the image into Paint, then save the image as a PNG.
Leo van soldt
Post by Leo van soldt » Sat Jul 30, 2011 11:16 am
Hallo Gale,
Thank you very much for your quick reply.
Indeed, I was looking in the http-link you mentioned.
I have found the click Removan in the Effect-menu.
Thanks a lot for your help.
Regards,
Leo van Soldt
