COMPRESSOR FAILS IN GETTING LOUD RESULTS
slx5c
Post by slx5c » Fri Jul 22, 2011 5:07 am
:geek: Audacity 1.2.6 on Windows 7 and the Compressor is set to default threshold -12 ratio 2:1 attack .2s and normalize to 0.
My saved Wav file is amplified to maximum without clipping. I open fiIe use the edit tool to select all of the track and then use the effects tool to get compressor, I preview and it is perfect, I then use compressor by pressing ok, and the final outcome is that it is not loud like the preview button when it is pressed.
Re: COMPRESSOR FAILS IN GETTING LOUD RESULTS
Post by steve » Fri Jul 22, 2011 9:55 am
The recommended version of Audacity for Windows 7 is Audacity 1.3.13.
The compressor effect in Audacity 1.3.13 is much improved over the 1.2. version.
More info:
http://manual.audacityteam.org/man/Compressor
samspots
Post by samspots » Tue Jul 26, 2011 8:23 pm
This should get you along for loudness:
http://www.gvst.co.uk/gmax.htm
Have fun.
