Now my Q for 1.3 is this, record a record & as it's playing you see the sound waves, end, hit stop & the recording becomes a single line & you cannot hear anything on playback! So what am I doing wrong?
Problem Recording with upgrade to 1.3 Beta
3 weeks ago I got a turntable with 1.2 software included, recording on 1.2 wasn't a problem once I figured out I had to save file as AUP then export as wav,file, even though the sound level was very low on the recorded CD.
Re: Problem Recording with upgrade to 1.3 Beta
I think I understand your question, but could you post a couple of screen shots to illustrate the issue. There is a screenshot tool in the Help menu of Audacity 13. Make sure that the "Save Images To" location is somewhere on your local machine that you have write permissions for.
Is your computer on a network?
Which version of Windows?
Hi I'm running win7 (64 bit)+
Having now done this Audacity won't shut down!
What's the total length of the recording?
How much free disk space do you have?
What are the settings in "Edit menu > Preferences > Directories"?
Total length of record 1 x 45 rpm = 2.49 Seconds.
No Network Standalone system. Free Space 603GB.
Recording Audio to Buffer 100. Correction 130.
Playback preview length 3 sec. cut region 1 sec, After cut 1sec, Short period 1 sec Long period 15 sec. Sample rate 44100Hz 16 Bit fast Sinc. -96 db (PCCM range of 16bit samples). View Mode "Waveform". FFT Window "256 default". Type "Hanning". Max Freq 8000Hz.
Effects: LADPSA,Nyquist, VAMP, VST, Display VST.
I tried to screen copy as per last time but it didn't like it , so hence the written word.
Sorry, it was the "Directories" tab that I was interested in.
(No problem that I can see with the settings that you have reported)
Hi
And the answer is? or do you still need more information?
Still wondering what settings you have in "Edit menu > Preferences > Directories"
Sorry, but in the last reply you said (Quote) "Sorry, it was the "Directories" tab that I was interested in.
(No problem that I can see with the settings that you have reported) so I thought you didn't need the the Directories tab!
Anyway here is.
Free Space: 602.5GB
Audio Cache: Play &/or record using RAM (box not ticked)
maximum Free Memory (MB) :16
Anyway here is.
Free Space: 602.5GB
I don't see any obvious clue there either.
Coming back to the problem description - I'm still not 100% clear about what exactly you are seeing.
I've looked again at the sequence of images that you have posted - could you describe what exactly is happening there.
Does "it" happen all of the time?
