Editing Earlier In The Track Without Moving Later Section
Manglehold
Post by Manglehold » Thu Jun 23, 2011 6:08 pm
I would have thought that by 'splitting', I could move or paste things earlier without pushing the later separate splits.
How do I edit the track without moving the later segments?
billw58
Re: Editing Earlier In The Track Without Moving Later Sectio
Post by billw58 » Thu Jun 23, 2011 8:29 pm
Edit > Preferences, Tracks panel, uncheck "Editing a clip can move other clips".
-- Bill
solanus
Post by solanus » Thu Jun 23, 2011 8:41 pm
Add another track, and paste into that track. The first track won't be affected, and later you can "Mix and Render" the tracks back to a single track if you want.
You will find that if you are splitting and shuffling around segments of audio, it's WAY easier to work with several tracks open.
You can also easily drag segments around on the track and even from one track to another using the Time Shift Tool.
