In the help section:
How do I download and install the LAME MP3 encoder?
Go to the LAME download page <http://lame.buanzo.com.ar/>.
Under "For Audacity 1.2.6 and 1.3.3 on Windows", left-click on the link "libmp3lame-win-3.97.zip" and save the zip folder to anywhere on your computer.
When you have finished downloading the ZIP folder, unzip it and save the file lame_enc.dll that it contains to anywhere on your computer.
The first time you use the "Export as MP3" command, Audacity will ask you where lame_enc.dll is saved.
I remembered something I saw in the winLAME site home page so I went there and read what it said.
I copied this Q.:
Q: Can I copy a newer lame_enc.dll into winLAME's folder to update the LAME version?
A: No; winLAME uses a self-made API to LAME (which eases access for winLAME) that is packaged into a DLL called nLAME.dll. This DLL cannot be exchanged with other (renamed) DLLs that contain newer versions of LAME. When a new version is released, check back on this site if an update is available. (on a sidenote, DVDx uses nLAME.dll, too, for encoding the audio track of a movie).
Sense I am new to all this and don't know anything much about either program, Isn't there something wrong here?
I am thankful for any help I get.
