1.3 Recording Issue
copeyd
1.3 Recording Issue
Post by copeyd » Tue Jun 14, 2011 1:12 pm
On playback after I've been recording sometimes the tune from my left CDJ will only play out of the left speaker, and vice versa, so even when it's been mixed in well because they are still two separate sounds coming out of separate speakers it doesn't sound right, any ideas?
DVDdoug
Forum Crew
Re: 1.3 Recording Issue
Post by DVDdoug » Tue Jun 14, 2011 8:42 pm
Are you connected analog or USB/digital?
Do you have the same problem with the playback/monitoring system, or is it just the recording?
Is there a balance control. Are you using a mixer? If so, check you pan controls on the mixer.
Any other details you can give us?
