Following feedback from initial testing of the new functionality, Martyn has made a couple of changes that should stop the furrowed brows happening in the future:
I have made a further commit that:
1) Disallows +ve values by greying out OK and Preview.
2) Converts a positive number found in prefs to a negative (but see below re presets).
3) Defaults the max amplitude to -1.0dB (a sensible value, and showing that it should be negative to new users).
4) Save/Load the presets from [Presets], rather than [CSPresets]. This has the side effect of ignoring previous versions.
This will mean that it should be impossible to generate clipping with Normalize in the future (unlike now, where entering a negative number in the box will induce clipping) - to do that you would need to go to the Amplify effect where clippng is "frowned upon" by the GUI but can be forced by ticking the check-box to allow clipping (if that's what you really want to do, for whatever reason).
I haven't had a chance to test these yet, I will have to wait for the next 1.3.14 nightly build.
Normalization of stereo tracks
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
waxcylinder
Re: Normalization of stereo tracks
