Audacity Segmentation Faults
koyophoto
Post by koyophoto » Sat Jun 04, 2011 7:19 pm
I am having problems with Audacity seg-faulting. It happens when the computer is running resource-intensive programs in addition to Audacity. It segfaults as soon as I click stop or when I am saving. It doesn't happen every time either, only when the computer is especially bogged down by the other program (Mediashout 4).
Thanks for any help.
Re: Audacity Segmentation Faults
Post by steve » Sat Jun 04, 2011 7:42 pm
Operating system?
Audacity version?
koyophoto
Post by koyophoto » Sun Jun 05, 2011 12:39 am
Windows Vista and Windows 7 with the latest release of Audacity (1.2.6).
Post by Gale Andrews » Sun Jun 05, 2011 1:24 am
koyophoto wrote:Windows Vista and Windows 7 with the latest release of Audacity (1.2.6).
Did you build that version and are running it from Visual Studio?
Please see the release notes for 1.2.6 which explains the problem:
http://audacityteam.org/download/release-notes
We are no longer fixing issues in 1.2.6 because we want to replace it with a new 2.0 version based on Audacity Beta. You can get the latest release for Windows Vista and 7 (1.3.13 Beta) here:
http://audacity.googlecode.com/files/au ... 1.3.13.exe
koyophoto
Post by koyophoto » Tue Jun 07, 2011 8:47 pm
I just downloaded the executable. I can try the beta.
