HELP! ERROR 2(cant find file specified)
mmmblueberrypie
Post by mmmblueberrypie » Fri Jun 03, 2011 10:54 pm
My track was done. I closed it to go hook it up to its charger. Then when I tried to open it again i got this message:above. It has the beat that I copied but none of my audio. All of the audio boxes are still where they are supposed to be, however they have nothing in them. only one box has a few seconds in it that still has the right audio. Can someone please help me out. Also, when I go to open audacity it is a little different then before. The files in Audacity used to be Languages, Nyquist, plug-ins, AUDACITY -which i used!----it is not there anymore.,then comes license, aud help, readme, audacity,exe. I dont know if this help, but I thought it might. I am using a hp laptop.
Thanks for the help people.
Re: HELP! ERROR 2(cant find file specified)
Post by steve » Sat Jun 04, 2011 10:43 am
When exactly do you get the error message?
Did you Save the Audacity Project? If so, where and with what name?
Did you Export the recording?
What version of Windows are you using?
What version of Audacity are you using?
