Are Apple effects free software?
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
amichail
Post by amichail » Thu Jun 02, 2011 3:58 pm
Are they under a different license from the rest of Audacity?
Can they be used to modify sounds for commercial purposes?
Why the need to mention that they are Apple effects in the menu?
billw58
Re: Are Apple effects free software?
Post by billw58 » Thu Jun 02, 2011 4:15 pm
Don't know the answers to the first two questions. As for the third, my guess is that names like "Apple: AUBandpass" are simply passed to Audacity when it queries the OS for available AU effects.
-- Bill
Post by steve » Thu Jun 02, 2011 5:41 pm
amichail wrote:Are they under a different license from the rest of Audacity?
Probably. I presume that they are under the same license as the rest of your operating system, whereas Audacity is GPL.
amichail
Post by amichail » Thu Jun 02, 2011 5:49 pm
It's not even clear that they are part of the OS. They might come from Apple sample code for example.
The important thing though is whether I can use these to modify sounds for commercial purposes.
Post by steve » Thu Jun 02, 2011 6:03 pm
Which effects are they?
Is there no indication of the license on the effect interface?
amichail
Post by amichail » Thu Jun 02, 2011 6:12 pm
steve wrote:Which effects are they?
It says "Manufacturer: Apple" in the dialog boxes for these effects.
Most people are probably not even aware that OS X comes with these effects, so they may wonder where they came from.
Maybe something like this would prevent confusion (if true):
"This sound effect comes with OS X and you may use it to modify sounds for any purpose."
Post by steve » Thu Jun 02, 2011 6:44 pm
I think that for a definitive answer on this you would need to check with Apple, though I would expect that you can use them for commercial work - after all, Apple don't prevent you from using Apple fonts for writing commercial documents.
Post by kozikowski » Fri Jun 03, 2011 1:56 pm
Nobody forces you to say "Picture Editing by Photoshop." What you can't do is include Photoshop itself in your product.
bgravato
Post by bgravato » Fri Jun 03, 2011 3:23 pm
If this is part of the initial MacOS-X package, then the same license agreement that you accepted when you first installed MacOS-X should apply. Read the OS-X license agreement and see if is there any clause that forbids you to use the audio effects for commercial purposes... I doubt it though.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
Post by kozikowski » Sat Jun 04, 2011 2:59 am
Nobody is racing to use on-line software. It's too easy to "own" the users work by clever manipulation of the user agreement.
Written works produced and edited on Word-Squirter® software become the exclusive property of Squirt International -- all rights including international distribution......etc.
There have been several instances of this back-door ownership already.
And since everything is on-line... You can't call the work back to your dumb terminal.
This is the way everything used to be done, except the computer in the middle was in the big room down the hall and if anything went wrong, you could walk down the hall and smack the systems administrator with a broom handle if you needed to.
I liked that broom-handle approach.
