I've been using 1.2.6, decided to upgrade to 1.3.5 - noise reduction much better, now. However, I can't persuade this thing to give me access to label tracks. I have the strange feeling that I am missing the menu from which I access it - is there supposed to be a "Tracks" menu?
Second little problem - I don't have access to most of the effects in the plugins folder - what's up with that?
Am I just looking in the wrong places? I'm using an intel MacBook, OSX 10.5.3.
Thanks.
missing menus?
Re: missing menus?
<<<I'm using an intel MacBook, OSX 10.5.3.>>>
If you're on an Intel machine, you should have been using Audacity 1.2.5 not 1.2.6.
So it would be really good to go back and make sure you got the right 1.3.
Re: missing menus?
Well, I'm using (trying to use) 1.3.5d, distributed in universal binary, which I assume is the correct version. Do I assume correctly? I've also tried 1.3.3, which has the same problems. Suggestions?
Re: missing menus?
Just to give al ittle more info - on 1.2.x I see the following menus: File, Edit, View, Project, Generate, Effect, Analyze, Help. The Project menu allows me to add a "New Label Track." Under Effect I see about 30 choices.
With 1.3.5d I have the following menus: File, Edit, View, Effect, Window, Help.
I can find nowhere that allows me to add a label track, and under Effects I have only six choices.
For interest, I downloaded 1.3.6a4, which added one menu, Transport.
So, is there something missing? I believe, from reading the postings here, there should be more menus, at least one. Thoughts?
- Quality Assurance
Re: missing menus?
Yes 1.3.5d is for PPC and Intel architectures. 1.3.5 d by default should have all the menus shown here:
http://www.apple.com/downloads/macosx/a ... acity.html
I think you may have turned CleanSpeech on by mistake which is a reduced GUI. You can turn it off on the Interface tab of Preferences (under Modes). Preferences should be under the Audacity menu, isn't it there? Or use CTRL + , to get to Preferences.
