fehler: not well-formed (invalid token)in zeile 6
andshey
Post by andshey » Sat May 28, 2011 12:00 pm
Hello I hope you can understand what I want (I am from Germany),
I have a problem with opening a file. I have worked on this file a lot of hours and know I cant open it. If I want to open the file there comes always the mistake " fehler: not well-formed (invalid token)in zeile 6"
please what can I do to safe the file.
1 Version.aup
(99.25 KiB) Downloaded 41 times
Re: fehler: not well-formed (invalid token)in zeile 6
Post by steve » Sat May 28, 2011 3:25 pm
Make a back-up copy of the file.
Open the original file in a plain text editor (for example, NotePad or NotePad++)
Look for the 6th line:
Code: Select all
<tag name="TRACKNUMBER" value="ã„&#x0080;"/>
and delete it.
Then save the file without changing the name or the extension.
Audacity 1.2 does not support Unicode characters.
