mic problems
twist Grizzly
mic problems
When I plug in my usb mic Imy audio does not work making it impossible to dub over my beats. How do I correct this problem?
twist Grizzly
Re: mic problems
Can anybody give a suggestion or a tip to what I should do?
Re: mic problems
That's too vague... you need to give us more info...
Start by saying which operating system you have and which audacity version (Help -> About).
What do you exactly mean by "audio does not work"? You can't listen? You can't record? Be more specific.
To record from usb mic you should connect the mic before opening audacity, then you need to choose the usb device in Preferences -> Devices -> Recording device.
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
