change tempo
This forum is now closed.
For help with current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the 2.x.feedback board.
dartie1
change tempo
Post by dartie1 » Wed May 25, 2011 6:18 pm
When I select all tracks and apply change tempo, some tracks go out of sync. I've tried to change tempo of each track separately and it still won't work..Ideas?
Re: change tempo
Post by steve » Wed May 25, 2011 6:28 pm
If you have some tracks that do not start at the beginning (time = zero) then they will go out of sync with tracks that begin at a different position. This is because leading "white space" is not time stretched. If you use "Mix and Render" (Tracks menu) on each individual track (one at a time), then each track will start at time=zero and should then stay in sync when you stretch them all together.
dartie1
Re: change tempo
Post by dartie1 » Thu May 26, 2011 8:50 pm
thanks Steve. It's worked perfectly.
