sound quality
lefty
sound quality
Post by lefty » Sat May 21, 2011 10:39 pm
I like the software, but the sound quality is poor. I'm recording from a CD player on the (dell) computer. The quality going that I record to Audacity is fine, but when I playback it is not good at all. Is that to be expected or do I have some setting(s) wrong?
thanks
Lefty
Re: sound quality
Post by kozikowski » Sun May 22, 2011 12:38 am
If you're trying to capture music from a Music CD, you shouldn't be doing it in real time. Use CDex or equivalent to "rip" the CD into WAV music files and use those.
tommytones
Re: sound quality
Post by tommytones » Wed May 25, 2011 12:03 am
I'm having the same problem, but with recording from a portable recorder. Any insight would be greatly appreciated!
Re: sound quality
Post by steve » Wed May 25, 2011 6:56 am
tommytones wrote:I'm having the same problem, but with recording from a portable recorder. Any insight would be greatly appreciated!
Need a lot more information.
What's wrong with the sound?
What equipment do you have and how is it connected?
tommytones
Re: sound quality
Post by tommytones » Wed May 25, 2011 9:59 pm
As far as sound, the volume is low when burning to a CD from itunes, despite using the compressor, eq, and g-verb while attenuating the gain.
I'm using a Tascam portable recorder (linear pcm) to import sounds to the computer using only audacity.
Tommytones
Re: sound quality
Post by steve » Wed May 25, 2011 11:50 pm
tommytones
Re: sound quality
Post by tommytones » Wed May 25, 2011 11:55 pm
thanks, great ideas on this!!!
