input level from cassestte deck causing distortion
I am trying to record from cassette deck to Audacity. I am going 'line out' from the deck to the 'mic' input on laptop. The levels are too high and I can't adjust them down. There is distortion. Also it seems like it might be restricted to mono? The main thing right now though is the distortion.
billw58
Re: input level from cassestte deck causing distortion
That's the problem. You need to connect to a line input. If you don't have one, you'll need to get a USB line level interface such as the Behringer UCA-202.tinkering wrote:I am going 'line out' from the deck to the 'mic' input on laptop
http://kozco.com/tech/audacity/pix/UCA202.jpg
-- Bill
That connection on your machine was designed to do this...
http://www.kozco.com/tech/audacity/pix/PCHeadset.jpg
Thanks for that Bill. I will try to get one of those from eBay.billw58 wrote:That's the problem. You need to connect to a line input. If you don't have one, you'll need to get a USB line level interface such as the Behringer UCA-202.tinkering wrote:I am going 'line out' from the deck to the 'mic' input on laptop
-- Bill
tinkering
