I do not know how to thank you, that was really a difficult task for you to answer, I am a difficult asker, and it was for me like a really needed almost classroom lesson to learn, that clarify things a lot
on the other hand I realize now that is not so easy to record if you do not know anything about the physics behind the sound and sound frequencies, so that is my flaw
When you say:
If the audio is very close to 0dB before applying the Equalizer, then applying boost to any frequencies may push the signal over 0 dB and cause it to distort when playing through the sound card.
I am actually concerned exactly about that, that I might not even realize if I distorted the sound, now that I understand that seeing the red clipping on the wave, is not the only tool to notice distortions, and so I have to ask same question again, sorry, where can I see if I "have pushed the signal over 0 dB" ?
Do i see it in Audacity in the linear meter of the playback when I play it back or in the waveform graphic? Or somewhere else?
When you say:
""in Draw Curves" view. If the amplitude before processing is a little low, then I will make the Eq curve mostly above the 0 dB line and if the amplitude is quite high I will make the Eq curve mostly below the 0 dB line"
That is an easy way to adjust for me, but, it sounds good, , but I am not sure I know what AMPLITUDE is exactly, are you referring to the shape of the waveform graphic? Or where in Audacity do I go to see if-- the amplitude level before I draw the curve, is either below or above 0 dB?
Yes i feel sometime that the recording has a hissy sound somewhere or similar,so referring to when you say:
if the recording sounds a bit "thin" (lacking bass) you may want to increase the bass frequencies. If the recording sounds "tinny" and "hissy" (excessive high frequencies) you may want to turn down the high frequencies.
Are you referring still to the "draw curve" view and not in the actual equalizer view?
Or are you referring to all those sliders in the Eq view?
And in both views---, how do i find the sliders for the bass frequencies and also the sliders for the high frequencies in that slider set? Is there a way to answer this question in an easy way?
And if in "draw curve" view how do I tweak the curve to adjust the bass and the treble? is this the same as AMPLITUDE? same thing? So it is always the same thing we are talking about but in different words?
Then a different question:
IS it possible, if I only have one or two red clippings in the graphic after the effects, to just select those tiny pieces and go into Amplify and reduce the noise with a lower value just in those selected pieces? or would that create a mess?
Yes I totally hear you about the noise removal, unfortunately because of my problem that I have never been able to resolve yet, with Bill's guidance , I was able to resolve it, only through Noise Removal, and I am glad that I can do that, and so I have to use that feature all the time
So, from here, my last question
As I really value your opinion so highly, can I do again a sample of the recording, first after the first usual steps, just Amplify and noise removal, then do another sample of same recording after I have further added some other effects, maybe Eq or BassBoost or SoftClips L-- or both , and let you be the judge?
I would appreciate that so very much
I still would like to learn about AMPLITUDE and the rest though!!
Thank you again for the effort, I appreciate it very much
Anna
