Recording problem
human9
Re: Recording problem
Post by human9 » Thu May 19, 2011 2:04 am
yes its the same turntable
Irish
Forum Crew
Post by Irish » Thu May 19, 2011 1:19 pm
It looks as though the problem is with the USB electronics in the turntable.
billw58 wrote:That turntable includes a phono pre-amp, so with the correct adapter - dual-female-RCA to stereo mini-plug - you can plug the RCA outputs of the turntable into the line input on the Mac and record that way.
Unplug the USB connection and try connecting direct from the RCA sockets on the turntable to the line-in on the Mac, as Bill and Koz suggested, with the cable shown in Koz's link. The EQ switch on the turntable should be set to Line, not Phono.
If that works OK, you know the problem is with the USB in the turntable.
POL
* * * * Tips * * * * Tutorials * * * * 1.3 Quick Start Guide * * * * Audacity 1.3 Manual * * * * Audacity wiki * * * *
billw58
Post by billw58 » Thu May 19, 2011 2:42 pm
Note that I was assuming the turntable has a permanently-attached RCA cable for connecting to a stereo, thus the need for an adapter with female RCA sockets. If the turntable has RCA sockets on the back for connecting a standard RCA cable, then you need a cable as illustrated in Koz's picture.
-- Bill
