DickN wrote:Gale Andrews wrote:I've added
Bug 406.
In Step 3, "Start playing the track or recording a new one" is unnecessary in my experience for most of the indicated behavior,
Yes the description says "Does not depend on playing or recording, but doing so usually shows the issue more clearly."
DickN wrote:Gale Andrews wrote:Peter has remarked to me by e-mail that:
Sometimes it does funny things with the waveform display by showing a section that it is not currently playing or labelling.
This isn't (I believe) new to 1.3.13. If you don't close the previous label, then you when you CTRL + M to add the new label, the Timeline position will jump back to the old label while it closes, and then move the Timeline to a new position with the old label centered in the waveform or the new label at the left edge of the waveform.
I've seen this but never considered it a bug. What should it do instead?
It's not being tracked as a bug because "what it should do" is to be discussed as part of a wider proposal about playback scrolling. But in a nutshell, I think it shouldn't move the Timeline position at all - as far as the user's intention is concerned the situation is the same as adding a new label at playback position when the previous label is already closed.
We should retain some way of giving focus back to the label when playback has pushed the label behind the scroll, but CTRL doesn't seem a good choice. Also typing more characters in the label once it has gone behind should not jerk you constantly between the label position and playback position.
DickN wrote:Another problem I'm having with 1.3.13, which I will have to check next time the time jump occurs. Occasionally the keyboard i/f gets into a state of mis-mapping the keys. The UP arrow and DOWN arrow become RIGHT and LEFT arrows, but the RIGHT and LEFT arrows behave normally. Sometimes the SHIFT key is logically (no, not mechanically!) stuck down as indicated by the icon on the PLAY button (I have a fuzzy memory of this happening with 1.3.12 too.). Tapping the SHIFT key gets that back in sync. I don't recall exactly what fixes the arrow keys, but I've never had to restart Audacity to fix it. Now, if the Ctrl key behaved as I just described for the Shift key, ... just thinking with my fingers here. I think I've only seen the arrow keys problem after I've typed something much faster than the display responds. It happened last night on the XP laptop.
SHIFT making Play display as Loop Play is already at
Bug 307. If you find steps to reproduce the arrow keys problem, please post them 1, 2, 3... At the moment I don't understand the context in which you are using arrow keys.
DickN wrote:
I had another strange experience last night but I'm not sure what led up to it nor was I very observant of the syndrome: Something went completely haywire when I pressed the Shift key and wasn't touching anything else. I think I had been making a string of long timeline jumps with the keyboard during Play, so it might be associated with the stuck Shift key behavior cited above. At some time last night I was unable to jump backward much faster than playback speed. This problem was corrected after I stopped and restarted Playback. It's apparent that something was just going wrong, because I got a "data execution" crash a little while later.
If you can reproduce this crash, please let us know. Note you can't jump playback behind the cursor - it's functionality we would like but doing it introduces other bugs.
DickN wrote:Gale Andrews wrote:I don't see either of DickN's behaviours on XP or Win 7 in 1.3.13:
DickN wrote:
(1) I'm finding that when I edit a label the display jumps horizontally when I hit <enter>, enough to put the label (if it's a point label) off the screen.
(2) The display sometimes jumps horizontally quite a lot, which becomes apparent at the end of the delay. While Transport was Stopped, I typed a range label and the during the delay I attempted to select a different nearby region of audio. There was no immediate response on the screen, but after the delay a select region appeared in the same screen position as the one I'd tried to select but the action took place after the jump so that a different actual time region was selected.
Do those two happen in 1.3.12 as well or only 1.3.13? Certainly the second behaviour with the selection in the wrong place occurs if you are playing and the selection isn't drawn until the waveform has moved on.
Only in 1.3.13. I can picture that last part happening, but note that in this case Transport was Stopped.
Does
(1) also happen without playing the track?
Can you list steps to reproduce 1, 2, 3... for
(1) and
(2) from launch of Audacity? Or is
(2) a special case of
(1)?
Thanks.
