steve wrote:I can't see the problem
Try these steps:
1) generate 9 hrs of noise (if you see the problem @ 9 hrs try with fewer & fewer hrs until the problem becomes unnoticeable); leave the entire show fit-to-window
2) start playing the noise (quick -- turn down the volume as needed<grin>) anywhere near the beginning
3) click in the wavetrack somewhere near the center
4) use your keyboard shortcut to insert a label (
<CTRL + b> by default)
5) rapidly press lots of random letters on the keyboard (try to avoid any "special" keypresses)
6) stop pressing keys after 50 or 100 presses
Does 1.3.13 keep up or is there a noticeable delay between when you stop and when the final letter displays in the label? Revert to 1.3.12(10/11), try again--delay?
The length of noise needed seems to depend on your CPU speed and maybe to some extent on your OS (with Windows)--might even depend on RAM speed. Fit-to-window might not be a critical factor; where you start playing is not really critical you just need time to do the testing; where you insert the label may not be critical you just need lots of on-screen room to display the label text without scrolling.
