Edgar wrote:
@both waxcylinder & dickN:
Can you give system details (CPU speed, RAM, OS w/ SP, disc space available)?
XP has SP3, machine is a laptop with 1.5G mem and CPU speed is typically around 850 MHz (nowhere near spec). Audacity typically reports 6-12 hours of available disk. This is the machine that is least affected by the issue.
The Vista (SP2) machine is 64b, 1.8 GHz quad-core with 4 GB RAM and over 200 recording hours of available disk space. This is the one most affected.
This behavior did not happen with 1.3.12 on either machine.
Edgar wrote:Can you give explicit steps (including kind & size of audio) leading to slow behavior?
Typically I have one mono track, generally in the 60-90 minute range, and I'm dropping point labels while recording or playing and range labels while stopped. If I type a long label text, on the Vista machine it is not echoed until after I stop typing. The "3-6 seconds" I mentioned previously is from the time I stop typing. It seems like it takes longer with a longer label text.
Edgar wrote:@dickN -- would you consider changing the thread title to something which might attract other users with this problem? Maybe something like:
Big delay in displaying characters typed into a label or when dragging tracks vertically
Sure! Uh, how do I do that? Won't all the replies have the old title?
