Hi Gales,
Thank you so much for replying with your advice. Okay I have made a little progress....
I have re-checked from Control panel, sounds etc) on 'record' and everything is ticked on ‘disabled devices’ & ‘disconnect devices’ as suggested – BUT nothing new shows up other than the original microphone. Microphone is ‘default Device’ with levels turned up high, 2 channel 16 bit, 44100Hz. The options you describe are not on my laptop i.e. stereo mix, ‘what u hear’ etc – also no new soundcard etc.
When I ‘right click’ microphone, then go into properties, below this it shows ‘controller information’ and says I have a ‘High definition Audio Device’ – going into this property it says the ‘device type’ is a ‘sound, video & games controller’; location 0 (internal High Definition Audio Bus’; This device is working properly; Drivers up to date.’ Also in microphone properties, there is a tab called 'listen' - I ticked 'listen to this device', it sounded awful - so clicked this off - but things then changed for the better.....
Yes I have set Audacity preferences to ‘host’ to ‘MME’ and recording device to ‘Microsoft sound Mapper’, ‘Imput’ – also ‘Microsoft sound mapper’ for ‘output’ – not sure if this is correct, please advise if this should be on speakers instead.
The good news – I can now (somehow???) record via microphone onto Audacity, its got lots of feedback and latency – yet it works. I have also recorded via mic from an mp3 player this too works.
Question: How do I set Audacity up to record directly (internally) what my laptop is receiving off the internet instead of going via the mic? Have tried connecting via headphones socket with a cable directly into mic – but only get loud machine gun noises. Are there preferences in Edit (Audacity) I need to adjust to direct it to record not via the mic? Or is my 1 year old laptop one of those machines that just won’t allow to record internally?
I downloaded Freecorder which does record internally, but I would prefer to use Audacity so that I can then edit it etc with ease.
Thanks so much for your time – your advice is a great help.
