I am using Audacity 1.3.13 (FreeBSD ports: audacity-devel) under FreeBSD 8.2-stable. I have also tried Audacity 1.3.12 and Auacity 1.2.4b_9 (FreeBSD port: audacity), and all versions exhibit the same problem. FreeBSD version:
Code: Select all
[email protected]# uname -a
FreeBSD kg-quiet.kg4.no 8.2-STABLE FreeBSD 8.2-STABLE #0: Sun Apr 3 19:49:05 CEST 2011 [email protected]:/usr/obj/usr/src/sys/GENERIC amd64Code: Select all
[email protected]# cat /dev/sndstat
FreeBSD Audio Driver (newpcm: 64bit 2009061500/amd64)
Installed devices:
pcm0: <ATI IXP 400> at memory 0xfe029000 irq 17 kld snd_atiixp (1p:2v/1r:1v) default
pcm1: <USB audio> at ? kld snd_uaudio (1p:1v/1r:1v)
pcm1 (shown as "/dev/dsp1: Line" in Audacity preferences, devices) is the usb sound device, used for recording
First of all; Audacity and this setup works, I can record, and I can playback sound afterwards. There is just one small problem; during recording, there is no sound. Yes, Software Playthrough is enabled.
A bit of debugging shows this (done while Audacity was recording)
Code: Select all
[email protected]# sysctl hw.snd.verbose=2
hw.snd.verbose: 1 -> 2
Installed devices:
snddev flags=0x2e2<AUTOVCHAN,BUSY,MPSAFE,REGISTERED,VPC>
[pcm0:play:dsp0.p0]: spd 48000, fmt 0x00200010, flags 0x00002100, 0x00000004
interrupts 1115, underruns 0, feed 1115, ready 0 [b:4096/2048/2|bs:4096/2048/2]
channel flags=0x2100<BUSY,HAS_VCHAN>
{userland} -> feeder_mixer(0x00200010) -> {hardware}
pcm0:play:dsp0.p0[pcm0:virtual:dsp0.vp0]: spd 44100/48000, fmt 0x00200010, flags 0x10000000, 0x00000029
interrupts 0, underruns 0, feed 0, ready 0 [b:0/0/0|bs:65536/2048/32]
channel flags=0x10000000<VIRTUAL>
{userland} -> feeder_root(0x00200010) -> feeder_volume(0x00200010) -> feeder_rate(0x00200010 q:1 44100 -> 48000) -> {hardware}
pcm0:play:dsp0.p0[pcm0:virtual:dsp0.vp1]: spd 44100/48000, fmt 0x00200010, flags 0x10000000, 0x00000029
[pcm0:record:dsp0.r0]: spd 48000, fmt 0x00200010, flags 0x00002100, 0x00000005
interrupts 0, overruns 0, feed 0, hfree 4096, sfree 4096 [b:4096/2048/2|bs:4096/2048/2]
{hardware} -> feeder_root(0x00200010) -> feeder_mixer(0x00200010) -> {userland}
pcm0:record:dsp0.r0[pcm0:virtual:dsp0.vr0]: spd 44100/48000, fmt 0x00100010/0x00200010, flags 0x10000000, 0x00000069
interrupts 0, overruns 0, feed 0, hfree 0, sfree 32768 [b:0/0/0|bs:32768/1024/32]
{hardware} -> feeder_root(0x00200010) -> feeder_matrix(2.0 -> 1.0) -> feeder_volume(0x00100010) -> feeder_rate(0x00100010 q:1 48000 -> 44100) -> {userland}
snddev flags=0x2e6<AUTOVCHAN,SOFTPCMVOL,BUSY,MPSAFE,REGISTERED,VPC>
[pcm1:play:dsp1.p0]: spd 48000, fmt 0x00200010, flags 0x00002108, 0x00000004
interrupts 910, underruns 0, feed 909, ready 0 [b:3072/1536/2|bs:4096/2048/2]
channel flags=0x2108<TRIGGERED,BUSY,HAS_VCHAN>
pcm1:play:dsp1.p0[pcm1:virtual:dsp1.vp0]: spd 44100/48000, fmt 0x00200010, flags 0x1000114c, 0x00000029, pid 58968 (audacity)
interrupts 0, underruns 33, feed 987, ready 2012 [b:0/0/0|bs:2048/512/4]
channel flags=0x1000114c<RUNNING,TRIGGERED,NBIO,BUSY,HAS_SIZE,VIRTUAL>
[pcm1:record:dsp1.r0]: spd 48000, fmt 0x00200010, flags 0x00002108, 0x00000005
interrupts 910, overruns 0, feed 1820, hfree 3072, sfree 4095 [b:3072/1536/2|bs:4096/2048/2]
pcm1:record:dsp1.r0[pcm1:virtual:dsp1.vr0]: spd 44100/48000, fmt 0x00200010, flags 0x1000115c, 0x00000029, pid 58968 (audacity)
interrupts 0, overruns 9, feed 2719, hfree 0, sfree 2012 [b:0/0/0|bs:2048/512/4]
channel flags=0x1000115c<RUNNING,TRIGGERED,NOTRIGGER,NBIO,BUSY,HAS_SIZE,VIRTUAL>
{hardware} -> feeder_root(0x00200010) -> feeder_rate(0x00200010 q:1 48000 -> 44100) -> feeder_volume(0x00200010) -> {userland}--
Torfinn
