Noise with very low sound music
Soldado266
Post by Soldado266 » Fri May 06, 2011 12:21 pm
Hi There,
I'm recording a podcast and I need a really low volume sound in the background.
The song I have is free from any type of noise, it's really really clear.
The problem is that when I decrease the amplitude to really low, there is an annoying wind like noise exactly when the instruments are playing.
Detail: I haven't subjected the song to any type of noise removal.
It is a Chinese song, there is no vocal, just some blimblimblim.
Hope you guys can give me insight on that.
Thanks!
Re: Noise with very low sound music
Post by steve » Fri May 06, 2011 12:44 pm
I think we are going to need to hear the problem.
Could you post a couple of short examples (just a couple of seconds) of (a) the original music, (b) the low level music that demonstrates the noise.
Short samples can be uploaded directly to the forum (see "Upload Attachment" below the message composing box). Longer samples would need to be uploaded somewhere else and a link posted.
Soldado266
Post by Soldado266 » Fri May 06, 2011 2:47 pm
Sure,
The files you asked are attached.
I muted out the vocal track that goes along with the LowLevelSong. I believe it would make even harder to detect the problem.
Thanks for the reply.
OriginalSong.mp3
(158.74 KiB) Downloaded 521 times
LowLevelSong.mp3
(635.1 KiB) Downloaded 284 times
Trebor
Post by Trebor » Fri May 06, 2011 4:30 pm
If the low level version is amplified to the same level as the original there is more hiss noise than the original ...
That relative increase in noise is inevitable: signal to noise ratio will be lower if the signal is lower.
A possibility worth considering is that you are hearing hiss noise which is generated by your apparatus and which isn’t actually on the low level recording, it’s just that the noise is more obvious when you are listening to a quiet recording.
You could use audacity’s “generate” to generate a truly silent track, any hiss you can hear when playing the truly silent track is generated by your kit: it isn’t on the recording.
ten seconds of true silence.wav
(861.37 KiB) Downloaded 75 times
bgravato
Operating System: Linux Debian
Post by bgravato » Fri May 06, 2011 5:21 pm
I can't notice any increased noise in the quieter recording... Of course if you amplify it or if you raise your speakers volume that you're amplifying the noise too and like Trebor said it may sound there's more noise in it, when actually there isn't...
Do the silent track test Trebor suggested.
How are you doing the mix with your voice?
You should import the original song to one track and record your voice on another track.
Do not change the amplitude of the music by using amplify (with negative gain). Keep it at the normal amplitude. Either use the gain slider in the track (-___+ slide in the track left panel) or use the envelope tool (that has the advantage that you can "shape" different amplitudes at different parts of the show (for example raising the volume of the music when you're not speaking). The advantage of this is that no change is actually done to the music track (at least until you mix and render and export the final show). So if you decide you want the music level louder you can just adjust the envelope or raise the gain slider and that won't increase the noise level like if you use the amplify effect.
When the editing is done you can export the show as wav or mp3 (or your preferred format) and it will automatically mix and render both tracks and respect both the envelope shaping and the slider gain in the final mix...
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
bgravato
Post by bgravato » Fri May 06, 2011 5:23 pm
All I said before is better explained in this wiki topic: http://manual.audacityteam.org/man/Tuto ... ound_Music
And because an image can be worth a thousand words, some screenshots/illustration on that page describe more accurately what I tried to explain in words...
Post by steve » Fri May 06, 2011 5:38 pm
Soldado266 wrote:The problem is that when I decrease the amplitude to really low, there is an annoying wind like noise exactly when the instruments are playing.
I don't hear any "wind like noise". How are you listening to it?
Soldado266
Post by Soldado266 » Sat May 07, 2011 1:40 am
I listened to the silent track (I had done before as well), and there was no sound at all.
The way I mixed it with my vocal was by placing the vocal track in a different/separate track.
I understand that perhaps some of you might not be able to hear it, it is quite subtle indeed.
It's weird though, some of my friends were able to hear it, some of them weren't.
I've got a theory, it might sound stupid but...
Perhaps the problem is caused by something intrinsic to the process used by the ear phones to produce the sound (They way it vibrates to produce the sound waves).
I say that because I checked some mp3 files of mine and when I set the volume really low I could hear the same noise again.
I'm gonna check some of the things you guys mentioned... I'll get back to you soon with some answer/solution/explanation.
Thanks again.
Soldado266
Post by Soldado266 » Sat May 07, 2011 2:08 am
Trebor, why did you say that the signal to noise ratio is lower? When we decrease the signal amplitude by using compressor/amplify/envelope tool I thought the noise was also decreased , thus keeping the ration constant. No?
bgravato, I've read the link you sent me.Thanks!
steve, you really can't listen to it? I'm inside a studio with a head set. You can listen to it better if you use one of those earphones that you stick in you ear. If you have a good quality one is even easier to notice.
Tks
Post by steve » Sat May 07, 2011 12:05 pm
What I mean is that I hear no more noise (in absolute terms) on the "Low level" version than I hear on "Original" version. If anything there's slightly more hiss on the "Original" version, but it's mostly masked by the sound of the music.
