How to create a multi track
picturehead
Post by picturehead » Fri May 06, 2011 11:38 am
No problem when I record one track. When I add a new track for backing vocals, it's impossible to play the first track. Probably there's is something wrong with my settings but I don't know what.
Re: How to create a multi track
Post by steve » Fri May 06, 2011 12:04 pm
picturehead wrote:When I add a new track for backing vocals, it's impossible to play the first track.
More detail please.
Why is it impossible?
How are you recording? What equipment are you using?
picturehead
Post by picturehead » Fri May 06, 2011 12:31 pm
I use Eurorack MXB1002 and Windows XP
First I made a recording of guitar and vocal (two mics, one track). I can listen to the track.
Now I want to add some backing vocals. So I create a new track and after that I use the red recording button. I can record, but don't hear the first track with guitar and vocal.
Post by steve » Fri May 06, 2011 12:57 pm
You do not need to "make a track" before you start recording. When you press the Record button a new track will automatically be created.
To hear the first track while recording the second, you should have these options near the bottom of the "Transport" menu:
Software Playthrough: disabled (not ticked)
Overdub: enabled (ticked)
picturehead
Post by picturehead » Fri May 06, 2011 1:11 pm
Thanks for your reaction, steve!
I've tried this before. But when I ticked 'overdub', then I hear the first track with a lot of noice. First track seems to be re-recorded as midi.
Got a solution. Disable 'stereomix' in realtec manager
