This forum is now closed.
For help with
current Audacity, please post to the 2.x. board for your operating system.
Please post feedback about the current 2.x version on the
2.x.feedback board.
kamyogi
Post
by kamyogi » Thu May 05, 2011 3:40 pm
HI,
I am new to Audacity. Before downloading it, I have got a question.
Does it record audio when the URL is not located (as it is often the case with copy protected stuff)?
Thanks for the reply.
bgravato
Post
by bgravato » Thu May 05, 2011 4:28 pm
kamyogi wrote:HI,
I didn't understand your question... What are you exactly trying to record and from where?
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
Post
by kozikowski » Thu May 05, 2011 5:29 pm
Many programs will record "Audio Playing On The Computer," the restriction is usually in Windows Control Panels, not Audacity. Modern Windows installs make it very difficult to record "internal audio" and Macs don't have this ability at all.
kamyogi
Post
by kamyogi » Fri May 06, 2011 8:19 am
bgravato wrote:kamyogi wrote:HI,
Hi Bgravato,
I'll try to be more explicit this time. Go to this site
http://radio3.cbc.ca/#/music/ An audio stream will autuomatically start to play. You can stop it and play other music items proposed on the page (with play button). Now, when you play them, you don't have access to their URLs (stream address). One can just listen online through webplayer.
Is it still possible to record them with Audacity?
bgravato
Post
by bgravato » Fri May 06, 2011 10:10 am
kamyogi wrote:Is it still possible to record them with Audacity?
Maybe.
For doing what you want with Audacity is irrelevant if you can see the url or not. You need to configure Audacity to record what's playing on the computer. Audacity then will record any sound playing on the computer regardless of where it comes from (webpage, program, game, video, etc).
To achieve that you need to select Stereo Mix as the recording device. Whether this is available or not depends on what operating system you have (windows, mac, linux), which version of the OS and the drivers for your soundcard.
Check this topic on the wiki:
http://wiki.audacityteam.org/wiki/Recor ... e_computer
Does it help?
