I'm getting about a 1/2 second delay in monitoring what I'm recording. Can anyone tell me why and what to do to fix it?
Thanks!
Delay in listening while recording
mybigoldies
- Attachments
- Audacity settings
- Audacity setting.JPG (98.16 KiB) Viewed 940 times
- Quality Assurance
Re: Delay in listening while recording
You cannot "fix" the delay with software playthrough monitoring. If you must use a USB mic, upgrade to one that has a headphones jack for hardware monitoring. Or use a mic connected to the mic port of the computer then unmute the mic on the "Playback" side of "Sounds and Audio Devices" in the Windows Control Panel, which also gives you hardware monitoring. Whether that works depends on your sound device, but it many cases it will work.mybigoldies wrote:I'm getting about a 1/2 second delay in monitoring what I'm recording. Can anyone tell me why and what to do to fix it?
