recording problem
drcharles
recording problem
Post by drcharles » Fri Apr 29, 2011 7:14 pm
I have a recurring problem with recording using Audacity 1.3.3. The software frequently changes settings on its own, without being touched by me even if I leave it open. Today, I recorded a 15-minute voice interview. It worked fine. I exported it to mp3 and that worked fine. I started a new recordng in the usual manner. Suddenly the sound meters were only moving a tiny amount, mcuh smalled than usual. I had changed nothing. WHen the recoring was doien, it autosaved as usual. I then exported it as usual to a new mp3 file. What I got was an mp3 of the first recording. My second recording was absent. I ent looking for my autosaved copy and couldn't find it. even though autosave is checked in preferences, there is no .audacity_temp file on my computer that I can find. Where is the separate folder it mentions? It doesn't tell you where it saves the autsaved files int he documentation. Any idea where to look?
A relted problem is taht without warning it will delete my input from preferences. I use a USb input and sometimes its just gone. I have to reinstall fromt he beginning. any idea what causes this?
bgravato
Re: recording problem
Post by bgravato » Fri Apr 29, 2011 8:22 pm
Audacity 1.3.3 is very old... you should upgrade to the latest 1.3.13.
You can get it from here: http://audacityteam.org/download/
(moved to the 1.3.x forum)
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
