Direct connection between VOX TONELAB ST and AUDACITY?
javierf55
Post by javierf55 » Sun Apr 24, 2011 5:26 pm
Hi all,
I have been trying to set a connection between a VOX TONELAB ST and Audacity trough the USB cable and the Asio driver but is not working; besides, the manual is very poor in that part.
Can anyone give me some light on what to do for a working connection? do I have to go somewere in Windows 7 for defining the connection?
waxcylinder
Re: Direct connection between VOX TONELAB ST and AUDACITY?
Post by waxcylinder » Sun Apr 24, 2011 5:29 pm
Have you seen this page in the Audacity manual: http://manual.audacityteam.org/man/Reco ... turntables
javierf55
Post by javierf55 » Sun Apr 24, 2011 9:56 pm
Thanks WC it was so simple ; the main screen of the version 1.3.13 has the option to choose which microphone to use, once connected you can just select Tonelab. Simple, easy and great.
Thanks for writting.
