3.5mm mic's into mixer output to pc?
Did you buy a new mixer? Do you need advice? Post here.
Re: 3.5mm mic's into mixer output to pc?
Post by kozikowski » Sun Apr 04, 2010 2:15 am
While I crank through all that, I noticed that not once in that post to you tell us what the show is. What is it? I can feel the next request coming that eight people around a conference room table are intending to Skype into a conference with three other cities. You'll need to record both sides of all the conversations.
Did I hit it?
Post by kozikowski » Sun Apr 04, 2010 2:22 am
<<<7 Logitech headsets, which I bought primarily for the microphones and the convenient place to stick 'em, I only plan on using 6 mics at a time, but it would be nice to have 8 inputs. >>>
Model numbers or web page?
<<<A Nady 4/8 channel mixer, which I've learned doesn't supply the necessary power to the headsets, therefore it's being (temporarily?) rendered obsolete.>>>
Maybe temporarily inappropriate, but we'll tell you that right after you tell us which Nady.
<<<A crapload of 1/8" to 1/4" adapters,>>>
What kind, which sex, and which direction? 1/8"stereo socket to 1/4" mono plug?
http://www.radioshack.com/product/index ... Id=2062462
<<<Window 7 with Audacity, though I can't imagine this part matters. >>>
Not directly. If you're on a large deskside machine, the mixer should plug right in. If you're on a Windows Laptop, it typically won't be possible to plug the mixer in without an adapter. We'll tell you that right after you tell us all about the computer.
aighead
Post by aighead » Sun Apr 04, 2010 5:01 am
Ha! Thanks for being curious! It's http://aighead.com/presents or aighead.com presents: whichever you prefer. For the most part it'll be several us sitting around a table in the aighead.compound carriage house just telling lies. There is no Skyping (yet, but I'd prefer to keep it that way) and the reason for my desire of 8 channel is occasionally there will be anywhere from 2 to 7 of us sitting around, and I'd like to have an extra channel for some random noise input (synthesizer style). I'd be happy with 4 channel and a splitter or two if I knew it would work.
Ok, now on to the real info...
The headsets are these, and I'm not concerned about the headphone part at all, we'll all be close enough to hear the conversation without having monitors to listen through, and they are light enough to not muffle any sound. http://www.logitech.com/index.cfm/webca ... 8&cl=au,en
The mixer is: http://www.nady.com/mm242.html and again, I'd be fine returning this one and getting something else, again, assuming it works.
The adapters are all 1/8" female to 1/4" male and they vary, I've probably got enough stereo to stereo, stereo to mono, mono to stereo, and 6 mono to mono that I just bought today (mono versions of the one you linked to).
I'm using a laptop with 1/8" mic and line in inputs...
All that to say that ideally I'd like to be able to keep the headsets (though I now realize that may be unlikely) due to their inexpensiveness and I'm pretty happy with their sound. If there is inexpensive workarounds I'm certainly willing to do some work (like searching for hours trying to figure out what the heck is wrong) to get things going. Just so you know you (and this forum) are much more helpful than the Nady support folks.
Thanks again for your help!
Post by kozikowski » Sun Apr 04, 2010 5:40 am
Don't go crazy until we unscramble you.
The headset information is supremely unhelpful. Do you have two plugs hanging from each headset, say one pink and one black?
You have an almost there system.
The headsets are designed to plug into a computer. The stereo earpieces get their sound from the headphone system in the computer (or iPod, or wherever). The microphone works from a five volt power system inside the computer and it delivers a very tiny mono voice signal to the sound card.
That's the top and bottom illustrations here...
http://www.kozco.com/tech/audioconnecto ... ctors.html
The mixer is close but no cigar. Yes, it will mix eight high level things down to one show on one wire. What it will not do is supply the power needed by the headset microphone, but more importantly, it will not boost the microphone signal the thousand or so times needed.
<<<I'm using a laptop with 1/8" mic and line in inputs...>>>
Typical Windows laptops do not have Stereo, High Level, Line-In. Does it say you have that, or are you assuming that from the large deskside computer you used to have. Deskside machine do have both as a rule.
We need to chew on this for a little while. Any specific reason the people around the table are wearing headphones?
aighead
Post by aighead » Sun Apr 04, 2010 7:34 am
My bad, yes 2 plugs. One pink, one black.
Correct with the pictures.
Both the mic and the line in are 1/8". So, in total I have a spdif headphone jack, mic, and line in inputs, all 1/8".
There is no reason for everyone to have headphones other than them being attached to the inexpensive microphone, I wasn't planning on plugging them in anywhere. They are there for decoration and looking cool.
Thanks again man!
Post by kozikowski » Sun Apr 04, 2010 5:08 pm
<<<My bad, yes 2 plugs. One pink, one black.>>>
No, you're fine, the web site declines to tell anyone about the connections. I know, I looked.
I keep getting drawn into the system I designed for one of the conference rooms at work. It came in about $200USD. Four cheap (self-powered) Radio Shack microphones [http://www.radioshack.com/product/index ... Id=2102927] mounted in pressure zone configuration and evenly spaced around the table. They feed a small Peavey mixer [http://www.sweetwater.com/store/detail/PV6/] and then on to a video conference unit [http://www.lifesize.com/Products/Video/ ... m_220.aspx]. It worked spectacularly well and they're considering copying it at one of the other locations, but it was mostly hand-built with custom woodworking and audio adapters. Not something you'd attempt without a good handy-person on the staff.
You can duplicate this work with a commercial sound system for only about 4 to 5 thousand dollars - US. I know. I looked.
Instead of plugging it into a conference unit, you plug it into your Mac, or large Deskside PC, or PC Laptop with USB adapter.
That's the other part of this puzzle. You're designing a relatively plain, multi-microphone live sound shoot. Past one microphone in a computer system, you need to add lots of external stuff like mixers and monitors and headphones (for the producer). Many people would kill to be able to plug multiple microphones straight into their laptop. Not so far. Multiple microphones take management.
A while back someone designed "Aggregate Mode" which allowed two microphones to appear in one computer. That worked until you needed to manage one microphone (make it louder) without the other. Sorry. Can't do that.
Peavey makes the PV6 with a USB output now. That came out after I bought mine. That will plug into any type of computer.
So that's where we are.
Post by kozikowski » Sun Apr 04, 2010 5:13 pm
Missed one.
Yes, you can totally build a battery inserter for your existing headsets. I've done that multiple times using the posted wiring diagram, but you do need to park the circuits inside a metal box because you are messing with tiny, tiny voice signals and they need to be shielded.
After that, you still need to get the signals into a microphone amplifier of some sort. That's where I use the Peavey.
aighead
Post by aighead » Mon Apr 05, 2010 5:45 am
As it stands right now, I have what amounts to be a super cheap version of what you speak of with "I keep getting drawn into the system I designed for one of the conference rooms at work".
My version works but it also picks up my noisy, noisy recording environments, not to mention that I'm a relatively low talker, mixed with some of my buddies who are extra loud.
How difficult and expensive is the circuit method, and am I correct in assuming that I'd need a circuit for each microphone?
I've got a small guitar amp laying around somewhere, is that what you are talking about or is the mixer you've linked to also an amp? I'm again worried if I'm going to pick up immense hums, my experience removing hum has been semi-unsuccessful. Also at that point could I still use the mixer I already have?
Without knowing anything about circuitry, is this something that a relatively competant new circuiter can manage? It looks simple enough, but I don't know what any of it means...
Seriously, I can't thank you enough for your understanding and putting up with my ignorance.
Post by kozikowski » Mon Apr 05, 2010 8:08 pm
<<<My version works but it also picks up my noisy, noisy recording environments>>>
That's part of the fun of doing this. You can't record any of this in a boiler factory or a bus station. That's where the noise canceling headset microphones shine. That's why I didn't say the words "the headphones gotta go." Headsets may be the only way to pull this off.
Post by kozikowski » Tue Apr 06, 2010 4:41 am
Here's all the pieces you need for a single channel. The missing parts are the cable to the computer and the computer itself.
This is the same thing put together. This mixer will handle four microphones.
Here's an explosion of the power supply.
Here's a detail.
I used two 3 volt coin batteries to simulate the 5 volts coming from the computer. I didn't even mount the batteries. I just pushed them into plastic sleeves and stuffed the whole thing into the case.
I believe all these items are available at Radio Shack.
Here are the overall system parts you need.
-- Noise canceling microphone
-- Battery for the microphone
-- Microphone amplifier
-- Sound mixer
-- Connection to the computer for recording.
If you have a laptop computer, you'll probably need one of the USB adapters we reviewed like the UCA 202. This mixer can be gotten with USB interface.
The headset with noise canceling mic you already have. The battery can be added with the home-made adapter. The microphone amplifier and mixer are the same box in this case. That's a Peavey PV6 and will manage four microphones.
Connection to the computer changes with the computer. PC laptops typically need USB somewhere.
Here's a view of the Radio Shack 3013 microphone...
...taped to a board for conference use. This microphone has its own battery supply built-in. Plug it into the mixer through an adapter and go..
