Moving the track window left or right
Audacity 1.3.x is now obsolete. Please use the current Audacity 2.x.x package for your distribution or compile Audacity from the source code.
pwabrahams
Post by pwabrahams » Sat Apr 23, 2011 4:20 am
Is there any way to move the track window left or right other than by using the slider beneath it? Like some key combination, perhaps?
Re: Moving the track window left or right
Post by steve » Sat Apr 23, 2011 1:35 pm
Scroll left/right: left/right cursor keys
Small jump left/rght; comma/dot keys.
Big jump left/right: Shift+comma/Shift+dot
Go to end: "End" key
Go to start: "Home" key
Also, if you have a wheel mouse
Ctrl+Mouse wheel = Zoom
Shift+Mouse Wheel = scroll
See here for the shortcut reference in the manual http://manual.audacityteam.org/man/Keyb ... _Reference
(The manual is usually also available in the Audacity Help menu)
pwabrahams
Don't move the cursor
Post by pwabrahams » Sat Apr 23, 2011 2:08 pm
I wasn't clear about what I'm missing. I want to move the waveform left or right without changing the position of the cursor relative to the waveform. It's the keyboard equivalent of moving the scrollbar underneath the waveform. In fact, Ctl-Left or Ctl-Right would be a very nice way to invoke this operation, since those key combinations don't have any meaning now.
Post by steve » Sat Apr 23, 2011 3:03 pm
Without moving the cursor you can either scroll using Shift+Mouse Wheel, or just drag (with the mouse) the scroll bar that's below the tracks panel (as was your original description). If you are regularly needing to scroll forward and back you probably just need to adjust the zoom level.
bgravato
Operating System: Linux Debian
Post by bgravato » Sat Apr 23, 2011 3:32 pm
You may also make a new post on the feature request forum suggesting that feature: http://forum.audacityteam.org/viewforum.php?f=20
Include as much details as you can in your post (Audacity version, Operating System, Equipment used, etc).
Please post your question in the appropriate forum (regarding audacity version and operating system).
pwabrahams
Will make the suggestion
Post by pwabrahams » Sat Apr 23, 2011 7:30 pm
There are workarounds, as you note, but nothing currently provides an exact keyboard equivalent of moving the scrollbar. I'll take your advice and post the suggestion for Ctl-Left and Ctl-Right.
